19 years agoAltera Devices with built-in Clock ???
Hi All, Can someone tell me if any Altera devices have a built-in Clock? I currently use the max7000 series (7064/7128) chips for small projects such as lighting chasers and low-speed cont...
19 years ago --- Quote Start --- I guess i'd simply feed this 3-5mhz signal into a divide-by-n counter, to give me a clock in the order of 100'sHz to a few KHz. --- Quote End --- Even if you have lots of positive clock setup slack at these low frequencies, you have to be careful about clock hold at any frequency, especially if you will have any paths crossing to or from the divided-down clock domain. If you have all your logic on the divided-down clock and make it global, you'll probably be OK without having to do anything extra. See my posts at http://www.alteraforum.com/forum/showthread.php?t=754 for more information.
