19 years agoAltera Devices with built-in Clock ???
Hi All, Can someone tell me if any Altera devices have a built-in Clock? I currently use the max7000 series (7064/7128) chips for small projects such as lighting chasers and low-speed cont...
19 years agoHi,
This might also help: http://www.altera.com/literature/hb/max2/max2_mii51010.pdf One interesting text at page 9-8 --- Quote Start --- Instantiating the Oscillator without the UFM You can use the IO/MAX II oscillator megafunction selection in the MegaWizard® Plug-In Manager to instantiate the UFM oscillator if you intend to use this signal without using the UFM memory block. Figure 9–4 shows the altufm_osc megafunction instantiation in the Quartus II software. --- Quote End --- Looks like this oscillator can be used, where the timing is not critical and this much (3.3-5.5 MHz) tolerance is acceptable, probably from device-to-device. I haven't used this feature so far, but if someone here is using this feature, then he/she can solidify this concept and its usability. If the variation in output frequency from device-to-device is very little, then this is really a nice feature, especially for low frequency applications. -BD
