19 years agoAltera Devices with built-in Clock ???
Hi All, Can someone tell me if any Altera devices have a built-in Clock? I currently use the max7000 series (7064/7128) chips for small projects such as lighting chasers and low-speed cont...
19 years agoThe December 2006 MAX II handbook (there might be a newer one) says this in the User Flash Memory Block section:
--- Quote Start --- Internal Oscillator As shown in Figure 2–15, the dedicated circuitry within the UFM block contains an oscillator. The dedicated circuitry uses this internally for its read and program operations. This oscillator's divide by 4 output can drive out of the UFM block as a logic interface clock source or for general-purpose logic clocking. The typical OSC output signal frequency ranges from 3.3 to 5.5 MHz, and its exact frequency of operation is not programmable. --- Quote End ---
