14 years agoAltera DE2 jtag issues
I'm working with an Altera DE2 board using Quartus II (v12 build 178) running on Ubuntu (6.06), which is installed through Parallels (Build 3188) on a Mac Pro (OSX 10.4.11, 2x2.66GHZ Dual-Core Intel Xeon, 2GB Ram). Lots of fighting and playing finally got Quartus to recognize that a board was connected to the computer, but I'm still having issues. It's probably worth noting that I know almost nothing about linux and am learning as I go while trying to get the FPGA board working.
I cannot get Quartus to successfully program the board. It knows a board is connected (or, it at least now lists USB-Blaster as hardware to which I can write a program), but when I try to program the board with a sample program, I get "Error (209040): Can't access JTAG chain". Running the JTAG chain debugger in Quartus II, any test gives "Error: JTAG chain problem detected" and "Error: No device detected". When I run "jtagconfig --debug" via the terminal, I get:1) USB-Blaster
Unable to read device chain (JTAG chain broken)
Captured DR after reset = ()
Captured IR after reset = ()
Captured Bypass chain = () When I've looked other places for help, there were always strings of numbers in the parenthesis following the ='s. But, clearly, I don't get anything. I have the same problems regardless if I've copied pgm_parts.txt to "/etc/jtagd/jtagd.pgm_parts", as I've seen suggested a few times in other places. It appears to clearly be a JTAG software problem, but I don't know enough about linux to try much more than I've listed here. Any help that can be offered would be much appreciated.1 Reply
Fixed it! It turns out, turning the board ON helps it talk to the computer.
