15 years agoAltera Cyclone III - Passive Serial mode
Hi, all. I have a Altera Cyclone III device installed on board. In order to upgrade of FPGA software, I decided to use Passive Serial programming mode. The FPGA image file will be saved in a pe...
15 years agoHello,
for this way of fpga programming you can use .rbf (Raw Binary File) file format.go assignments -> settings -> device and pin options, then in programming files tab check "Raw Binary File (.rbf)" and in configuration tab check "Generate compressed bitstreams". This will generate compressed .rbf file during compilation. br
