CLoon1
8 years agoAltera Cyclone II Quartus II JTAG Programming Error
I'm trying to program a Cyclone II I bought here (https://rads.stackoverflow.com/amzn/click/B00LEMKR92) using Quartus II 13.0sp1 on Arch Linux. I'm trying to program it with a very simple Verilog pro...
Vicky1
8 years agoHi,
"I am using a JTAG USB blaster. When I run jtagconfig, I receive the following output"
Since 'jtagconfig' command working correctly then this issue may occur due to following reasons,
- Check .sdc file name is same as project name or not, if available.
- Check the below link for cyclone II device,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an039.pdf
https://datasheet.octopart.com/EP2C5T144C8-Altera-datasheet-7627975.pdf
I have not replicated this issue but I hope this might help to you.
Best Regards
Vikas Jathar
