14 years agoAltera Classic PLCC Programming
Hi there, just joined the forum. I have a problem with obsolete Classic PLCC chips, being: EP1810LC-25T, which is used to control an embedded controller with a Motorola 68020 CPU. The seem...
14 years agoHi Gerry,
Thank you for the prompt reply. The Altera EP1810LC PLCC is used in an interface card for the Sinclair QL, which adds 2Mb ram and a 68020 CPU running at 20Mhz. The EP1810LC only seems to work if chip has a date code of: C9707 or earlier. I am not sure why this is. Can you recommend a replacement and a suitable programmer, my HILO ALL03a Programmer can use an adapter to program the EP1810, but I can find the adapter. So I guess it is a new programmer. Derek
