14 years agoAltera Classic PLCC Programming
Hi there, just joined the forum. I have a problem with obsolete Classic PLCC chips, being: EP1810LC-25T, which is used to control an embedded controller with a Motorola 68020 CPU. The seem...
14 years agoHI Derek,
Not sure I can help you regarding the date code part of your question, but I can shed some light on the Erasure of the EP1810. Check out the ordering info from a 1991 Altera Data Book. Link from my Hobby electronics Website. http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_classic_part_numbers.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_classic_part_numbers.jpg) The "EP1810LC" part number as you can see from the diagram the "L" indicates a one-time-programmable component. It could be that components after a particular date that were normally OTP, became Electronically Erasable. For instance the EP1810LC components. See this page From a 2001 Datasheet: http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_part_numbers.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_part_numbers.jpg) As you can see in the form from the link above....for the "L" suffix EP1810 components, the OTP is no longer indicated. However I'm not %100 sure that this is the case. Regards, -Gerry
