14 years agoAltera Analog
Hi I wanted to connect the LV-EZ1 ultrasonic range finder (sensor) to the de2 board. How do i connect this to the board this sensor gives a voltage depending on how far the object is located? ...
14 years agoto avoid complications since you are a beginner, just use the analog output (AN) on your board, interface it with external ADC circuit, connect the ADC outputs to the FPGA, and write a translation code for the digital inputs received by the FPGA from the ADC and feed it to the Seven segments or LCD as you wish
