14 years agoAltera Analog
Hi I wanted to connect the LV-EZ1 ultrasonic range finder (sensor) to the de2 board. How do i connect this to the board this sensor gives a voltage depending on how far the object is located? ...
14 years ago --- Quote Start --- I am not sure but i am thinking its the UART standard. How do i start with this implementation ? --- Quote End --- It does sound like a UART format to me too. Worst-case, its RS232 at non-standard voltage levels, and all you need to do is invert the signal to convert it to UART format. You should be able to instantiate an Altera UART - look in the Embedded Peripherals IP Guide. http://www.altera.com/literature/ug/ug_embedded_ip.pdf Cheers, Dave
