14 years agoAltera Analog
Hi I wanted to connect the LV-EZ1 ultrasonic range finder (sensor) to the de2 board. How do i connect this to the board this sensor gives a voltage depending on how far the object is located? ...
14 years ago --- Quote Start --- I wanted to connect the LV-EZ1 ultrasonic range finder (sensor) to the de2 board. How do i connect this to the board this sensor gives a voltage depending on how far the object is located? --- Quote End --- You read the data sheet. http://www.maxbotix.com/uploads/lv-maxsonar-ez1-datasheet.pdf The sensor has both serial output and a PWM output. You can probably interface to those easier than the analog output, which would require you use an analog-to-digital converter. Cheers, Dave
