14 years agoALTER Programming Unit (APU) unknown device Windows-7
The Altera Programming Unit (APU), when connected to a USB port on a Windows-7 machine causes an "Unknown Device" indication to occur on the "Devices and Printers" control panel. I have tried to loca...
14 years agoHi Craig,
I use the Altera PL-APU programmer on my old Windows XP machine without any problems. Not sure the released APU drivers will work on a Windows 7 machine. You may already have these drivers and the main issue is that you are running Windows 7 and they are not compatible. Regardless, if I were you.... you are probably better off to use a machine running Windows XP if you can. Considering the APU Drivers are dated 2003. Here is a download link off my hobby Website for the Altera APU drivers I am using with Windows XP. altera pl-apu usb drivers for windows xp (2003): http://www.digital-circuitry.com/files/altera/pl-apu/drivers/altera_pl-apu_usb_dirivers.zip (http://www.digital-circuitry.com/files/altera/pl-apu/drivers/altera_pl-apu_usb_dirivers.zip) Keep me posted on your progress. Kind Regards, Gerry O'Brien http://www.digital-circuitry.com/ (http://www.digital-circuitry.com/)
