11 years agoALTDDIO - 16bitx250MHz to 32bitx125MHz - Proper Timequest timing closure?
Hi, I'm using ALTDDIO to convert source-synchronous 16-bit/250 MHz data to 32-bit/125 MHz data. The device is a Cyclone V E. I'm trying to figure out how to properly constrain this interface. I have ...
11 years agoHi, it might be worth having a look at AN433
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an433.pdf I think for source sync ddr you will also need some false paths and possibly some multicycles in your sdc to make sure the timing is analysing the correct edges.
