12 years agoALTASMI_PARALLEL sector erase problem
Hi all, I'm using ALTASMI_PARALLEL IP (QuartusII 13.0sp1) to program an EPCS16 from a CycloneIVGX (EP4CGX22CF19C8), but the sector_erase command returns an illegal_erase error. If I repeat the s...
12 years ago --- Quote Start --- The problem is not solved, I'm using the workaround: a dummy read after ReadSID and ReadStatus operation. --- Quote End --- My problem was my bad. It seems it is required for the project to have the 'inputs tri stated for active configuration pins in user mode' box unchecked in device pins and options. Probably unrelated to your problem. However I could not figure out for the life of me why I was getting illegal erase and write assertions.
