12 years agoALTASMI_PARALLEL sector erase problem
Hi all, I'm using ALTASMI_PARALLEL IP (QuartusII 13.0sp1) to program an EPCS16 from a CycloneIVGX (EP4CGX22CF19C8), but the sector_erase command returns an illegal_erase error. If I repeat the s...
12 years ago --- Quote Start --- Did you manage to solve this? --- Quote End --- The problem is not solved, I'm using the workaround: a dummy read after ReadSID and ReadStatus operation.
