12 years agoALTASMI_PARALLEL sector erase problem
Hi all, I'm using ALTASMI_PARALLEL IP (QuartusII 13.0sp1) to program an EPCS16 from a CycloneIVGX (EP4CGX22CF19C8), but the sector_erase command returns an illegal_erase error. If I repeat the s...
12 years ago --- Quote Start --- Hi all, ......I'm using ALTASMI_PARALLEL IP (QuartusII 13.0sp1) to program an EPCS16 from a CycloneIVGX (EP4CGX22CF19C8), but the sector_erase command returns an illegal_erase error..... --- Quote End --- Some more info: it happends for very first write operation also, see attached picture Just an update, as you can see from Altera Knowledgement Data Base http://www.altera.com/support/kdb/solutions/rd12092013_489.html?gsa_pos=5&wt.oss_r=1&wt.oss=altasmi_parallel (http://www.altera.com/support/kdb/solutions/rd12092013_489.html?gsa_pos=5&wt.oss_r=1&wt.oss=altasmi_parallel) it seems the ALTASMI_PARALLEL IP it is unable to execute Write and Erase operation correctly after ReadID or ReadStatus operation. Altera claims the problem is solved on QuartusII 13.1. By the way, I try with QuartusII 64-Bit 13.1.1 Build 166 11/26/2013 SJ Full Version (Windows 7 64-Bit OS) and the problem persists.
