14 years agoALTASMI_PARALLEL - erase fails
I'm using the ALTASMI_PARALLEL Megafuncion with a Cyclone III and EPCS16 flash memory. On some production boards the ALTASMI indicates that a sector erase has been successful but in fact the sector has not been erased. The clock is well within specifications and I have implemented the required two clock delay. Any suggestions please?1 Reply
Sector could be protected. Check the illegal_erase status of ALTASMI_PARALLEL, if set it will indicate that sector is protected.
