16 years agoalt_tick() never exits
I'm having all sorts of problems adapting an existing design to run under v9.1. I have a cut-down design that runs, and now I'm trying to add another component to the SOPC, but with bizarrely random results.
The first build I had simply refused to verify on-chip memory. The second build (I changed nothing) now downloads, but doesn't even get to my main() function. It's stuck in alt_tick(), looping forever with alarm=0. This is going to drive me postal. Anyone else has this problem???3 Replies
I had the same problem, I believe it is due to the tick interrupts coming in faster than the NIOS can process them. You can prevent the interrupts from starting by copying the file alt_main.c from the bsp project into your application project and commenting out the following line.
alt_irq_init (NULL); This will prevent all interrupts from being initialized. Another solution should be to slow down the timer so the NIOS is not overloaded with interrupts. - Altera_Forum
I have the same problem.
I've already check the project and I think the .ptf file is ok. It seems a problem in the memory management but I'm not sure. Does anyone know anything more about this? Thanks in advance - Altera_Forum
I would check the postion of your *.ptf file. Is your project linked to the right file?
