12 years agoalt_read_flash too slow?
I have NIOS-II processor, compiled with Quartus 12.0 I was wondering if the following performance is reasonable: When I call alt_read_flash and read an entire flash block (256KBytes) I measure t...
12 years agoMaybe something is doing a sector erase - 500ms would be about right for that.
I looked at the low level flash functions a few weeks ago, IMHO you want to use the lower level functions (about two levels down) so that you can write partial blocks (ok if the old data if 0xff - or rather if the write doesn't need to set any bits). Might be worth adding some trace to thiose to see what is taking all the time. Also see if a read of 128k actually takes 1/2 the time - ie is it a per byte cost or a fixed overhead.
