Fdominguez
4 years agoAgilex SGMII bridge on E-Tile
Target: Agilex
Tools version: Quartus Pro 21.3
We are trying to implement this diagram found in the “Embedded Peripherals IP User Guide” to convert a HPS EMAC to SGMII interface coming from the ...
Ash_R_Altera
4 years agoHi,
In your original query you enquired about the TSE IP, which does not have a PMA only option.
If you use E-tile XCVR PHY IP at 1Gbps data rate, the PCS and MAC should be implemented in the FPGA fabric. There is no PCS available in this IP.
If using TSE IP, you can use the hard IP for 10G/25G and 100G data rates only.
Hope this clarifies.
