Fdominguez
4 years agoAgilex SGMII bridge on E-Tile
Target: Agilex
Tools version: Quartus Pro 21.3
We are trying to implement this diagram found in the “Embedded Peripherals IP User Guide” to convert a HPS EMAC to SGMII interface coming from the ...
Ash_R_Altera
4 years agoHi,
The E-tile cannot support the 1GbE. It has hard blocks supporting 10G/25G and 100G only.
The logic that you generate through this IP will mostly be implemented in the FPGA fabric for an E-tile device.
- Fdominguez4 years ago
Thanks for the reply
I am not planning on using MAC from the E-Tile. Instead I want to use the EMAC from the HPS and just use the E-Tile in pass-through mode for SGMII PCS
You are saying just using the SGMII PCS only is then not supported on the E-Tile hardened IP? Even if I were to use it for 10GE it would show that I can't use SGMII PCS only mode
