Agilex F series ICCMAX of all power rails
You can calculate field-programmable gate power consumption for Intel Agilex devices using the Intel FPGA Power and Thermal Calculator, and for more accurate power estimation, use the Power Analyzer in the Intel Quartus Prime Software. Intel recommends that you switch from the Intel FPGA Power and Thermal Calculator to the Power Analyzer once your design is available.
Do you have full design? We would recommend you to use Power Analyzer inside Quartus if you have your design.
Thank you.
Hi AminT
I know about PTC. it need more data from verilog project. I just need a maximum data for power design. Do intel have these data?
- AminT_Intel4 years ago
Do you have full design or not?
- fupwang4 years ago
Hi
I do not have a full FPGA design. Want to assess power consumption before starting board design and FPGA design.
We cannot assume the maximum current because different design requires different current consumption. Thus, the only way for you to know the value is to have your full design ready.
Thank you.
