Agilex 5 E-Series Ethernet with 1588 via HPS EMAC
Good day,
I would like to use the Hard Processor System (HPS) Ethernet Media Access Controller (EMAC) peripheral (with IEEE 1588) for a Gigabit Ethernet (GbE) port. I found the information for this in the Hard Processor System Technical Reference Manual - Agilex 5 SoCs (814346).
I will use an external PHY and SGMII Interface. I would thus route the signals through the FPGA IOs. Should I use the HSIOs or a Transceiver for the SGMII signals?
How should the MDIO signals be routed? the PHYs I use allow for up to 16 PHYs to be connected via one MDIO bus. Is it possible to combine a non-HPS and HPS GbE port over the same MDIO bus? The PHYs will have different addresses. How should I then route this bus?
Do I still need to use the Triple-Speed Ethernet IP when I use the EMAC?
Aik Eu is OOO.
Yes you can use the SGMII and SGMII+ using soft logic with the appropriate general purpose, TDS, or transceiver I/O resources. Reference-https://www.intel.com/content/www/us/en/docs/programmable/814346/24-1/phy-interface-01.html
You can also route the MDIO pin to FPGA and with shared MDIO interface for multiple PHY devices and their configuration and management.
Tiwari
- Nicole04
How will the shared MDIO be set up in the platform manager for the TSE IP?
Is it better to use an MDIO EMAC for the HPS EMAC connected ethernet link?
- Jeet14
- Jeet14
Hi
Let me know if you have any query on this.
Tiwari
- Jeet14
Aik Eu is OOO.
Tiwari
- Nicole04
Good day,
I have an SGMII connection to an XCVR which I would like to connect to the HPS EMAC. I am unsure how to set up the soft logic for the SGMII to GMII bridge.
Should I use the Multirate ethernet IP?
Kind regards,
Nicole
- Nicole04
Hi Aik Eu,
Thank you for your reply.
I will then not use the Triple-Speed Ethernet IP for this connection.
Should I use a transceiver or the HSIOs (with TDS) for the SGMII connection between the PHY chip and the FPGA (EMAC)?
If I have another ethernet connection that has to be connected to the FPGA fabric (via SGMII through a transceiver), which will use the Triple-Speed Ethernet IP, can I use a shared MDIO bus between this connection and the EMAC one? Where will the MDIO signals then be connected?
Thank you for your assistance.
Kind regards,
Nicole
- aikeu
