Agilex™ 7 FPGA I-Series Development Kit - Only one PCIe RP Gen4x4 on the R-Tile
Hi Serge93,
Thanks for reaching out.
If you choose Gen4 4x4 mode, the system will generate a PCIe IP with four x4's PCIe link through PCIe port bifurcation. According to the Table 13., 4x4 bifurcation mode will have Port 0, Port 1, Port 2, and Port 3 active.
If you wish to use only one Gen4 1x4, you can connect only the signals for Port 0, and leave the other ports' signal floating. For example, leave rx_n_in4 to rx_n_in15 and rx_p_in4 to rx_p_in15 unconnected, and do the same for tx signals. Additionally, leave other signals that starts with p1_x, p2_x, and p3_x, which are dedicated to the respective ports unconnected.
Ven
- Serge931 year ago
HelloVen,
Thank you for your answer.
But I am a little bit confusing about your example on selecting Port 0.
From the table below, in 4x4 mode, Port 0 is connected to Pcie lanes 4-7
So the lanes to leave floating are Pcie lanes 8-11, 0-3 and 12-15, correct ?
Serge
