KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
JohnT_Altera
6 years agoHi,
From the FPGA code, I do not observed that you performed watchdog timer reset. You will need to assert RU_nRSTIMER since you enable the watchdog timer. Please refer to table 34 in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf in order to performed watchdog timer reset
