13 years agoAdvice on FPGA pin choice for a kit.
I am designing a kit vor academic use here at my university. I am using an EP4C6 device with 144 EQFP package. For some reasons, not importanting mentioning here, i wont be able to leave all pins rou...
13 years ago --- Quote Start --- But regarding the original question, i could not understand your final opinion. Considering that there are already 2 dedicated clock pins and 51 IOs, what do you recomend to do with the remaining pin? Clock or IO? --- Quote End --- An I/O pin. However, resistors are essentially free (and so are empty PCB pads), so you could also route the last header pin via a resistor to both an I/O and the clock input pin. Load the I/O resistor by default. --- Quote Start --- In general, when you (or whoever is reading this) is using a generic kit, what usually would be a good relation of IOs and Clock pins. --- Quote End --- A clock pin per I/O connector is fine. If I want to test an ADC or DAC or some other device that needs a clock, then I would generally only want to test one of them, so one clock per I/O header is sufficient. More suggestions: 1) does the FPGA have PLL_OUT pins? Make sure you route some of them to the header. That way your users have the option of generating a clock at the FPGA and routing it to external logic. 2) power to the header If you have 3.3V on the header for powering external logic, add a jumper or a FET to control whether that power is on or off. Quite often I like to connect kits and if both kits have a power pin, this makes connecting them directly with a cable difficult - the power wire in the cable needs to be cut. Cheers, Dave
