18 years ago
address decoding in vhdl
hello,
I have a soft-core processor and an uart. in order to send the data from output of the processor to the input of uart vhdl module, i'm thinking that i need address decoding to writes the data into uart?? am i right?? but to do the address decoding in vhdl, i dont have any idea how to write it..can someone guide me on how to do this ?? Thx very much
regard,
bruno
    --- Quote Start ---
    hello vizzie,
    are selection lines the output data? and "00", "01" for example as addresses for the selection_lines??
    --- Quote End ---
    That's right. Selection lines is the output of the decoder. "00", "01" are the addresses from the hypothetical source; in this case your zpu processor.
    --- Quote Start ---
    "00", "01" are the addresses which you will be decoding. The "0001", "0010" etc. are the output selection lines of the decoder.
    --- Quote End ---
    hello vizzie,
    hello,
    in my attachment is my zpu_core(my processor) and a uart. mem_write is data output from my processor.it has 32 bits width.how to write an address decoder between zpu_core and uart serial?? i'm still thinking about it...any starting idea would be greatly appreciated..
    Thx
    --- Quote Start ---
    --- Quote End ---
    i still understand what you meant. the data output of my soft-core processor is 32 bits width. this data output will be passed to the input of uart. do i need address choices when only uart is connected to the processor and no other??
    --- Quote Start ---
    which one is the address for the uart? 00 or 01 0r 10 or 11? should i fix the address of uart in my uart module?
    --- Quote End ---
    --- Quote Start ---
    hello,
    --- Quote End ---
    It is very simple to write the VHDL code for an address decoder. A general code can be as follows:
    2-to-4 address decoder: Using if-else construct
    if address = "00" then
    selection_lines <= "0001";
    elsif address = "01" then
    selection_lines <= "0010";
    elsif address = "10" then
    selection_lines <= "0100";
    else address = "11" then
    selection_lines <= "1000";
    end if;
    You can also use "case-select" and "when-else" constructs to code an address decoder.
    You can use the higher address bus lines.
    Example: If you use the a12 and a13 lines
    cs=a12 and a13;
    cs is the chip select signal for uart. In this case the base address is 0x3000
