18 years agoaddress decoding in vhdl
hello, I have a soft-core processor and an uart. in order to send the data from output of the processor to the input of uart vhdl module, i'm thinking that i need address decoding to writes the...
18 years agoYou can use the higher address bus lines.
Example: If you use the a12 and a13 lines cs=a12 and a13; cs is the chip select signal for uart. In this case the base address is 0x3000
