15 years agoAdding Hex numbers
Hi, Does anyone know how can I add Hex numbers inside the process (VHDL)? For instance, I want to add x"55" + x"55" but if I'll write " x"55" or x"55" " the answer will be x"55" (the answer sh...
15 years agoI want to add two hex numbers inside the process…
This is my code: " LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; --USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.NUMERIC_STD.ALL; --I using "conv_std_logic_vector" function … signal TX_checkSum: std_logic_vector (8 downto 0); begin process (clk) begin if reset='1' then … elsif clk'event and clk='1' then TX_checkSum <= std_logic_vector(unsigned(x"55") + unsigned(x"55")); end if; end process; " I get the following error:" Error (10408): VHDL error at UART.vhd(139): can't determine type of object at or near string ""01010101"" -- found 25 possible types". What could be the problem?
