14 years agoAdding and resizing in one step
Hi, Is there a way to add two unsigned numbers and extract only the x most significant bits from it in one step? I want something like this: sum <= resize(number1 + number2,4) In...
14 years agoThanks kaz for your reply!
--- Quote Start --- sum = (num1 + num2)/2**4; --- Quote End --- I guess that in this case sum must have the same size as num1 and num2? I would rather have that sum already has the smaller size. --- Quote Start --- alternatively if you can accept truncation errors then: sum <= num1(6 downto 4) + num2(6 downto 4); --- Quote End --- I think I will go with this one. If there would be a way to avoid truncation errors, please let me know.
