14 years agoADC Timing Constraints
I feel like I see this question over and over, but can't quite figure out the answer. I've got an 125 MHz clock coming in, from which I generate a 62.5 MHz clock using a TFF, which I then use ...
14 years agoAs an aside note, why not use PLL since ADC clocked by your clock will suffer jitter and you may get around timing issues you have.
