14 years agoADC output from LVDS deserializer.
Hi, I have a an ADC sampling at 40 MHz, and it output LVDS signal, so i have to deserialize it using my DE2-115, but i am having trouble with the deserialized signal (shown in the picture), it ...
14 years ago --- Quote Start --- The said dynamic PLL dynamic phase shift feature is available for all Cyclone III - V FPGAs. It's a functionality you can use in your design, there's no ready-to-use IP block provided by Altera. --- Quote End --- really? that would be great!..is it called DPA (dynamic shift alignment) ? how do we activate this function? cause last time i check with altlvds_rx in Megawizard, it was grayed out, and someone in the forum said DPA is not available to Cyclone series. --- Quote Start --- Synchronization of received data to your system clock may be an additional issue. In your initial example, you simply used the LVDS_RX output clock. This is convenient but mostly doesn't fir the design requirements. --- Quote End --- would you mind explaining further on this? can i use a DCFIFO to capture the parallel data? would it solve the problem? Michael
