14 years agoADC output from LVDS deserializer.
Hi, I have a an ADC sampling at 40 MHz, and it output LVDS signal, so i have to deserialize it using my DE2-115, but i am having trouble with the deserialized signal (shown in the picture), it ...
14 years ago --- Quote Start --- I should add, the ADC i am working with, do comes with a bit clock (fast clock ) which is already 90 degree shifted for me. it is done inside the ADC. so i dont really need an extra PLL to phase shift it 90 degree. --- Quote End --- That's right. I assume, that the bitclock is just O.K. for the said 480 MBPS data rate. Near the Cyclone III speed limits, you may find an option to adjust the receiver phase helpful. This is much easier with a PLL. --- Quote Start --- but it is only available in the CYCLONE 4 GX or Stratix, not CYCLONE 4 E --- Quote End --- The said dynamic PLL dynamic phase shift feature is available for all Cyclone III - V FPGAs. It's a functionality you can use in your design, there's no ready-to-use IP block provided by Altera. --- Quote Start --- I want to use DDR format at the input and SDR at the output. i think it is done automatically by using altlvds_rx from the megawizard. --- Quote End --- Output from the LVDS_RX block is always SDR parallel data with the rate of the "slow clock" respectively frame clock. Synchronization of received data to your system clock may be an additional issue. In your initial example, you simply used the LVDS_RX output clock. This is convenient but mostly doesn't fir the design requirements.
