14 years agoADC output from LVDS deserializer.
Hi, I have a an ADC sampling at 40 MHz, and it output LVDS signal, so i have to deserialize it using my DE2-115, but i am having trouble with the deserialized signal (shown in the picture), it ...
14 years ago --- Quote Start --- Your sdc looks ok to me. Check report if you indeed got that. --- Quote End --- There is too much report data, i don't know where to look. Is this the one i should be looking for ? Info: Worst-case setup slack is 0.202 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: 0.202 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[0] Info: 3.436 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[1] Info: 47.987 0.000 altera_reserved_tck Info: Assembler is generating device programming files Info: Worst-case hold slack is 0.160 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: 0.160 0.000 altera_reserved_tck Info: 0.162 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[1] Info: 0.170 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[0] Info: Worst-case recovery slack is 49.169 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: 49.169 0.000 altera_reserved_tck Info: Worst-case removal slack is 0.471 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: 0.471 0.000 altera_reserved_tck Info: Worst-case minimum pulse width slack is 1.251 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: 1.251 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[0] Info: 1.867 0.000 HSMC_CLKIN_P2 Info: 12.205 0.000 inst|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[1] Info: 49.285 0.000 altera_reserved_tck Info: Design is not fully constrained for setup requirements Info: Design is not fully constrained for hold requirements Info: Quartus II TimeQuest Timing Analyzer was successful. 0 errors, 18 warnings Info: Peak virtual memory: 280 megabytes Info: Processing ended: Sat Oct 15 19:37:28 2011 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:03 Info: Quartus II Assembler was successful. 0 errors, 0 warnings Info: Peak virtual memory: 413 megabytes Info: Processing ended: Sat Oct 15 19:37:29 2011 Info: Elapsed time: 00:00:05 Info: Total CPU time (on all processors): 00:00:05 Info: Quartus II Full Compilation was successful. 0 errors, 517 warnings --- Quote Start --- If it is DDR, you will need constraints for both edges. You can also try rotate the PLL clock if you are using pll if you can't pass timing. --- Quote End --- like this ?. create_clock -period 4.15 [get_ports HSMC_CLKIN_P2] create_clock -period 4.15 [get_ports HSMC_CLKIN_N2] set_input_delay -clock HSMC_CLKIN_P2 -max 0.61 [get_ports HSMC_RX_D_P[11]] set_input_delay -clock HSMC_CLKIN_P2 -min 0.55 [get_ports HSMC_RX_D_P[11]] set_input_delay -clock HSMC_CLKIN_P2 -max 0.61 [get_ports HSMC_RX_D_N[11]] set_input_delay -clock HSMC_CLKIN_P2 -min 0.55 [get_ports HSMC_RX_D_N[11]] --- Quote Start --- Moreover, it could be timing not at io but at point when you sample the data on to 40MHz. Note 40MHs clock is edge aligned with data and you better do some shift away from edge e.g sample on opposite edge. --- Quote End --- I get what you mean, but how do i do "shifting away from the edge" ? Thank you for your advice. Michael
