16 years agoADC interfacing code for 3-wire SPI using Verilog
Hi guys, I'm writing some Verilog code to interface a simple 12-bit serial ADC to an FPGA and I have some questions about my methodology. The ADC that I'm using is the ADS7818 from Texas Ins...
16 years agoYour thinking seems correct to me. Except I think you are off by a clock cycle (actually half a cycle). The ADC will drive data out on the falling edge of clock. If you sample on the negedge of cycle 1, you're going to get the active low data enable rather than the MSB of the data.
I really think you ought to be doing everything here on the rising edge. How are you driving the clock to the ADC? It appears you need a 10ns hold time from the falling edge of clock to conv. You need to ensure this occurs. Again, use the rising clock edge. Consider the following://register declarations
reg conv;
reg rdy;
reg count;
reg data_temp;
reg tmp;
//The clock counter. Starts at 0, so clock is from 0-15 instead of 1-16.
always @ (posedge CLOCK_8)
count <= count + 4'd1;
//Assert the CONV signal
conv <= !&count;
//Read the serial data into a 12-bit register. Afterwards, convert it to parallel if the count is 13 (end of data stream)
begin
data_temp <= {data_temp,serial_data]};
if (count == 13)
tmp <= data_temp;
end
