14 years agoAdc /dac
Hello...i'm so new to verilog HDL n FPGA.... i want to ask is it possible to design ADC and DAC using Verilog HDL?. if possible how to design it? Thanks,
14 years agoIf you mean implementing a true ADC or DAC (i.e. using analog signals), with Altera devices the answer is No. FPGAs and CPLDs are inherently digital devices so you can interface an external A/D or D/A converter but you are not supposed to directly connect analog signals to the device pins.
Remarks: - other vendors may have mixed signal FPGAs, for example Actel Fusion devices. - a simple D/A conversion can be implemented driving a fpga pin with pwm, although you generally also need additional analog stages (buffer, amplifier, filter) out of fpga. - I even saw a couple of applications where digital FPGA pins (actually a LVDS receiver and a LVTTL output) were used to implement A/D conversion, through an external RC. Anyway this is a non conventional design and I don't think it leads to a straightforward implementation.
