10 years agoActive serial interface for Arria V
I am designing a board with Arria V FPGA with active serial interface. Device : 5AGXMB1G4F35C5N. I am using EPCQ256SI16N as a serial flash memory. I would be initially downloading the code using ...
10 years agoMSEL strapping look correct. You need power to pin 4 of your programming header - assuming it's intended for use with a USB-Blaster or similar. Check what voltage in the Arria V configuration section of the handbook (2.5V, I think).
Cheers, Alex
