11 years agoAchieving Timing Closure on Source Synchronous DDR Input
Hi I am looking for some help achieving timing closure in a design. I am using a TI ADS4149 EVM Board and connecting it to a Terasic C5 SoC Dev Board. The ADC outputs Source Synchronous D...
11 years agoI will try first the easiest options:
# create virtual clock latching data @ source
create_clock -name vir_clk_adc -period 4
# create clock that is received @ pin (90 degree shift)
create_clock -name clk_adc -period 4 -waveform {1 3}
derive_clock_uncertainty
# set input constraint using setup and hold wrt virtual clock# max = Tperiod/4 - Tsu# min = Th - Tperiod/4
set_input_delay -clock vir_clk_adc -max 0.250 *}]
set_input_delay -clock vir_clk_adc -min -0.250 *}]
set_input_delay -clock vir_clk_adc -max 0.250 *}] -clock_fall -add_delay
set_input_delay -clock vir_clk_adc -min -0.250 *}] -clock_fall -add_delay
# false path double data rate edges
set_false_path -setup -rise_from {vir_clk_adc} -fall_to {clk_adc}
set_false_path -setup -fall_from {vir_clk_adc} -rise_to {clk_adc}
set_false_path -hold -rise_from {vir_clk_adc} -rise_to {clk_adc}
set_false_path -hold -fall_from {vir_clk_adc} -fall_to {clk_adc}
if it fails timing try opposite edge transfer (fpga should deinterleave data accordingly)
set_false_path -setup -rise_from {vir_clk_adc} -rise_to {clk_adc}
set_false_path -setup -fall_from {vir_clk_adc} -fall_to {clk_adc}
set_false_path -hold -rise_from {vir_clk_adc} -fall_to {clk_adc}
set_false_path -hold -fall_from {vir_clk_adc} -rise_to {clk_adc}
