14 years agoAC/DC coupled LVDS on REFCLK
The Cyclone IV requires external termination if using AC coupled LVDS to the REFCLK pins. I have a couple of questions: 1- If the Vcm of the clock generator is compatible with the Vcm required...
14 years agoApparently, the CycloneIV Vcm spec you are refering to is attached to some LVDS inputs located in column I/Os whereas in your initial post you were talking about a REFCLK input which belongs to a GXB block.
So, if your clock oscillator is connected to the input reference REFCLK0 or REFCLK1 of a transceiver block, Vicm spec is slightly different (and a bit ambiguous to be true...). Nevertheless, with a 1.2Vcm it will work as well. If you are not using transceiver but true LVDS inputs, your clock source voltage levels are fully compliant so go ahead ! :-P
