14 years agoAC/DC coupled LVDS on REFCLK
The Cyclone IV requires external termination if using AC coupled LVDS to the REFCLK pins. I have a couple of questions: 1- If the Vcm of the clock generator is compatible with the Vcm required...
14 years agoThank you for the reply Oliver!
AC coupling is the best solution, but as the layout stands, it makes it a little hard to add the 4 resistors needed for a proper termination. That is the reason I am looking at DC coupling. The oscillator has the following LVDS output specs: Vcm = 1.2V Vod = 0.35 Vpp The Cyclone IV specs say that Vcm should be between 1.05V and 1.55V for that data rate I am using. That sounds like I am within the specs, is that correct?
