About the ground pad of E144-pin package
In the E144-pin package, there is an exposed ground pad on the bottom of the package. Does the FPGA work without this exposed ground pad connected to the ground plane of the PCB?
This question assumes that this exposed ground pad is poorly connected.
- YSuzu21
Operation is not guaranteed unless the bare ground pad is connected to the ground plane of the PCB.
Thank you very much. - MBenca
Hi Ysuzu21,
there is the following sentence in a pinout document for Intel MAX 10 device, 10M16SA (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/10m16sa.pdfThe E144-pin package has an exposed ground pad at the bottom of the package. The exposed ground pad is used for electrical connectivity and not for thermal purposes. You must connect the exposed ground pad to the ground plane of the PCB.
Martin
