16 years agoabout the error: Port "" does not exit in macrofunction \"NIOS"\
Dear friends I am a new user of the product named motionfire kit. Now, I meet a difficulty and want to consult you. when I started compilation for the FPGA project of motionfire kit, there a...
16 years agoHello Krish,
What kind of programmer are you using? is it byte blaster ? If you are using byte blaster and RS232 usb converter then you might run into problem due to the fact that both are using the same kind of driver. Please verify if you have byte blaster/altera programmer is in your system settings(meaning correctly installed) Then connect the programmer with your board and then start your system. you should be ready to go then. all the best.
