16 years agoabout the error: Port "" does not exit in macrofunction \"NIOS"\
Dear friends I am a new user of the product named motionfire kit. Now, I meet a difficulty and want to consult you. when I started compilation for the FPGA project of motionfire kit, there a...
16 years agoHi there i have had the same problem, and i sucessfuly solve it. First about problems with:
--- Quote Start --- Error: Port \"A_to_the_roto\" does not exist in macrofunction \"NIOS\" Error: Port \"B_to_the_roto\" does not exist in macrofunction \"NIOS\" Error: Port \"S_to_the_roto\" does not exist in macrofunction \"NIOS\" --- Quote End --- U need to find in file: openfire.vhdl all position with: A_to_the_roto B_to_the_roto S_to_the_roto and change it like u change roto library in SOPC Builder. For example: 1. In SOPC Builder u get error with roto library because of the same name was already use, so u rename it to for example: roto1 2. In openfire.vhdl file, found all place with text i said before and change it to: A_to_the_roto1 B_to_the_roto1 S_to_the_roto1 This is the solution for first problem. Now about the problem of: --- Quote Start --- Error: Port \"av_waitrequest_from_the_can0\" does not exist in macrofunction \"NIOS\" --- Quote End --- This is the software problem, in older version of Quartus ports in SOPC has different name in some of NIOS ports u generated. I find out that in Quartus II 10.0 port: av_waitrequest_from_the_can0 has been named as: av_wreq_from_the_can0 Like before u need to find all position in file: openfire.vhdl with text: 'av_waitrequest_from_the_can0' and 'av_waitrequest_from_the_can1' and simple change it to: 'av_wreq_from_the_can0' and 'av_wreq_from_the_can1' I think that is all, now i have problem with uploading program to the board. Anyone have idea why Quartus II Programmer don't see board?? Which is connected by RS232 converter to USB.
