16 years agoabout the error: Port "" does not exit in macrofunction \"NIOS"\
Dear friends I am a new user of the product named motionfire kit. Now, I meet a difficulty and want to consult you. when I started compilation for the FPGA project of motionfire kit, there a...
16 years ago---------------------
; Table of Contents ; --------------------- 1. Legal Notice 2. Archive Project Summary 3. Archive Project Messages 4. Files Archived ---------------- ; Legal Notice ; ---------------- +----------------------------------------------------------------+ ; Archive Project Summary ; +------------------------+---------------------------------------+ ; Archive Project Status ; Successful - Fri Jul 02 16:21:41 2010 ; ; Revision Name ; top ; ; Top-level Entity Name ; fpga ; ; Family ; Cyclone III ; +------------------------+---------------------------------------+ +--------------------------+ ; Archive Project Messages ; +--------------------------+ Info: File Set 'Source control' contains: Info: Project source and settings files Info: Automatically detected source files Critical Warning: Analysis & Elaboration was not run successfully Critical Warning: The 'Automatically detected source files' file subset will attempt to guess which files are needed. The archive file will likely be larger than required and may still be incomplete. Warning: Can't find required hierarchy file name.vhdl Warning: Can't find required hierarchy file outspi.vhdl Warning: Can't find required hierarchy file spileds.vhdl Warning: Can't find required hierarchy file debounce.vhdl Warning: Can't find required hierarchy file roto.vhdl Warning: Can't find required hierarchy file current_meas.vhd Warning: Can't find required hierarchy file current_regulator.vhd Warning: Can't find required hierarchy file encfol.vhd Warning: Can't find required hierarchy file fire_driver_itf.vhd Warning: Can't find required hierarchy file hallfol.vhd Warning: Can't find required hierarchy file integrator.vhd Warning: Can't find required hierarchy file limiter.vhd Warning: Can't find required hierarchy file open_fire.vhd Warning: Can't find required hierarchy file output.vhd Warning: Can't find required hierarchy file pi_regulator.vhd Warning: Can't find required hierarchy file position_meas.vhd Warning: Can't find required hierarchy file position_regulator.vhd Warning: Can't find required hierarchy file pwm_generator.vhd Warning: Can't find required hierarchy file speed_meas.vhd Warning: Can't find required hierarchy file speed_regulator.vhd Warning: Can't find required hierarchy file spi_control.vhd Warning: Can't find required hierarchy file open_fire_hw.tcl Warning: Can't find required hierarchy file open_fire.VHD Warning: Can't find required hierarchy file open_fire_hw.tcl Warning: Can't find required hierarchy file can_top.v Warning: Can't find required hierarchy file can_acf.v Warning: Can't find required hierarchy file can_bsp.v Warning: Can't find required hierarchy file can_btl.v Warning: Can't find required hierarchy file can_crc.v Warning: Can't find required hierarchy file can_defines.v Warning: Can't find required hierarchy file can_fifo.v Warning: Can't find required hierarchy file can_ibo.v Warning: Can't find required hierarchy file can_register.v Warning: Can't find required hierarchy file can_register_asyn.v Warning: Can't find required hierarchy file can_register_asyn_syn.v Warning: Can't find required hierarchy file can_register_syn.v Warning: Can't find required hierarchy file can_registers.v Warning: Can't find required hierarchy file openfire.vhdl Warning: Can't find required hierarchy file altera_europa_support.vhd Warning: Can't find required hierarchy file top.map_bb.hdbx Info: Not parsing encrypted file: alt_mem_phy_sequencer.vhd Info: Not parsing encrypted file: auk_ddr_hp_controller.vhd Info: Not parsing encrypted file: nios.vhd Info: ---------------------------------------------------------- Info: ---------------------------------------------------------- Info: Generated archive 'D:/motionfire/motionfire_fpga_09.1.1_restored/top.qar' Info: ---------------------------------------------------------- Info: ---------------------------------------------------------- Info: Generated report 'top.archive.rpt' Error: Evaluation of Tcl script d:/altera/91/quartus/common/tcl/apps/qpm/qar.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 8 errors, 268 warnings Error: Peak virtual memory: 123 megabytes Error: Processing ended: Fri Jul 02 16:21:41 2010 Error: Elapsed time: 00:03:10 Error: Total CPU time (on all processors): 00:01:31
