16 years agoabout the error: Port "" does not exit in macrofunction \"NIOS"\
Dear friends I am a new user of the product named motionfire kit. Now, I meet a difficulty and want to consult you. when I started compilation for the FPGA project of motionfire kit, there a...
16 years agothanks.
there are some error messages such as Error: Port "A_to_the_roto" does not exist in macrofunction "NIOS" Error: Port "B_to_the_roto" does not exist in macrofunction "NIOS" Error: Port "S_to_the_roto" does not exist in macrofunction "NIOS" Error: Port "av_waitrequest_from_the_can0" does not exist in macrofunction "NIOS" Error: Port "av_waitrequest_from_the_can1" does not exist in macrofunction "NIOS" Error: Result: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last. Error: Failed to discover source files from compiler. Check Analysis & Elaboration report. Error: Evaluation of Tcl script d:/altera/91/quartus/common/tcl/apps/qpm/qar.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 8 errors, 268 warnings Error: Peak virtual memory: 123 megabytes Error: Processing ended: Fri Jul 02 16:21:41 2010 Error: Elapsed time: 00:03:10 Error: Total CPU time (on all processors): 00:01:31
