14 years ago
about the CONF_DONE in the PS configuration
Dear all, I am trying to configure the Cyclone III device using the Passive Serial mode. In the very beginning, I draw the nCONFIG low, and subsequently the Cyclone III draw the nSTATUS low....the question is: why CONF_DONE is always low from the very beginning? As to the configuration handbook, there should be a high-to-low transition for the CONF_DONE... why?
In addition, there is said to be a low-to-high transition for the CONF_DONE in the end of the configuration, I just want to know, how does the Cyclone device know the configuration is done ?
PS. MSEL is 0000, and the clock is 1M, and the file format is .hex.
Thanks !
    --- Quote Start ---
    just found a that there are two different documents for this that tell me two different setting for MSEL
    --- Quote End ---
    The appropriate Cyclone-series handbook should be the only place you need to look. Which part (full part number please) are you using?
    Cheers,
    Dave
    --- Quote Start ---
    With the modifications, MSEL0 - pulled up to VCCA, MSEL1 & MSEL2 pulled down. The documentation I have says MSEL 0 to VCC and mSEL1 to GND. doesn't mention MSEL2.
    --- Quote End ---
    Cyclone III handbook:
    http://www.altera.com/literature/lit-cyc3.jsp
    Table 9-7, pp169-170: PS mode MSEL[3:0] = 0000b for standard POR, and 1100b for fast POR.
    Given that your device does not have MSEL[3] it must be one of the smaller packages.
    Your setting of MSEL[2:0] = 001b is invalid, it should be 100b or 000b.
    Cheers,
    Dave
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    Yes that is what I found in my search. The documents I was given and told to use were wrong. They are currently modifying my board now and I should know shortly.
    --- Quote Start ---
    --- Quote End ---
    Fixing the MSEL worked. I was able to send the full compressed .rbf and received the CONF_DONE. Thank you for all your help.
    --- Quote Start ---
    --- Quote End ---
    Awesome!
    So no need to skip the first 44 bytes?
    --- Quote Start ---
    --- Quote End ---
    You're welcome.
    Cheers,
    Dave
    --- Quote Start ---
    e
    --- Quote End ---
    No, I did not have to skip the first 44 bytes. I tried that first and it did not work. I had to send the full file.
    --- Quote Start ---
    --- Quote End ---
    Good to know, thanks!
    Cheers,
    Dave
