14 years agoAbout Stratix4 IO feature
The Stratix4 handbook said the setup time of input pin is about 200ps. Does it means a signal about 3Gbps could pass through the IO pins in Stratix4 devices, and I can use plural clocks(300MHz) wi...
14 years ago --- Quote Start --- In shrot, it works like a logic analyzer very much, a logic analyzer work in timing analyzing mode. --- Quote End --- ByteParadigm have a device that does this using a Xilinx part: http://www.byteparadigm.com/files/documents/thunderseries_wp.pdf Cheers, Dave
