14 years agoAbout Stratix4 IO feature
The Stratix4 handbook said the setup time of input pin is about 200ps. Does it means a signal about 3Gbps could pass through the IO pins in Stratix4 devices, and I can use plural clocks(300MHz) wi...
14 years agoI don't think regular I/O are the way to go. 3Gbps just seems way too out there. Could you use a transceiver and just hold the CDR unit in "lock to ref" mode instead of lock to data? That way you're not really recovering a clock out of it? (I may be way off base, just throwing out an idea...)
