14 years agoAbout Stratix4 IO feature
The Stratix4 handbook said the setup time of input pin is about 200ps. Does it means a signal about 3Gbps could pass through the IO pins in Stratix4 devices, and I can use plural clocks(300MHz) wi...
14 years ago --- Quote Start --- Is the hold time 0ns? I'm guessing not. I don't know why they even give setup/hold times anymore, since PLLs/delay chains allow you to shift to about any setup time you want(but always at the expense of hold). For 3Gbps, you would need to use the high-speed transceivers. For 1.6Gbps down to approximately 900Mbps, you can use LVDS with DPA. For 900Mbps downto 500MBps, straight LVDS should work. For below 500Mbps, regular I/O using DDR registers should work. Those are really rough figures off the top-of-my-head, and dependent on I/O standard, board layout, speed grade, the other device being connected to, etc., but hopefully in the right ballpark. --- Quote End --- Thanks for your answer. I'm trying to build a high speed data acquisition equipment using Stratix4. As you said, transceivers must be in use for 3Gbps. But the transceivers cannot work without a CDR(though the input data is random), in other words, they may not work in my design. So, i'm helpless. I want to sample the high speed data, but have no idea to acquired. The method of using FISO(Fast In Slow Out) chip will be helpful, but those chips always be used by companys like Agilent, Tek as ASIC. Seems no general FISO IC in market.
