About Power sequence
Hi Yamada1,
For powering up, as stated in the user guide, you may follow the guideline of tRAMP stated in the datasheet.
Additionally, all power rails must ramp up monotonically. The power-up sequence should meet either the standard or the fast Power On Reset (POR) delay time. The POR delay time depends on the POR delay setting you use. For the POR specifications of the Intel Arria 10 devices, refer to the POR Specifications section in the Intel Arria 10 Device Datasheet.
For your second question, it is generally recommended to ensure that these voltages start rising at the same time or follow a specified power-up sequencing. This synchronization helps maintain proper signal integrity, avoids potential issues related to voltage mismatches, and ensures reliable operation of the I/O circuitry.
Fakhrul
- Yamada13 years ago
Thank you for answering.
As for "For your second question,...", is this the answer to question 3)?
Sorry for the inconvenience, but thank you in advance.
